Delco SI alternator |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Topic: Delco SI alternatorPosted: 22 Mar 2018 at 8:06pm |
Have a tractor that sat for awhile and have to trip the relay to get the 1 wire alternator working every time the motor goes back to idle. Is the relay causing this issue or can the magnetic field be lost permently from sitting. I'm not a fan of these but, was already installed, I think they seem to draw some power when not in use.
Dakota Dave
Posted: 22 Mar 2018 at 8:14pm |
Delco SI alternators are internally regulated and don't have a relay. If you have a relay on one it's wired wrong.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 22 Mar 2018 at 8:22pm |
The 10 SI needs a higher RPM to excite and once output is established it will stay charging or regulating internally - no magnetism involved until electric flows - as not like a generator with residual or self exciting .
If it's drawing power when off - bad diode in diode trio - replace that . look on back and there should be a U shaped hole in back casting - just inside a bit is a tab - if you take a small screwdriver and touch case and that tab it should give you full output from alternator - if not internal regulator could also be bad Edited by Coke-in-MN - 22 Mar 2018 at 8:26pm |
allisbred
Posted: 22 Mar 2018 at 8:28pm |
No external relay, you would be correct, it is the regulator that I'm thinking about in the alternator. This tractor is new to me and has not been working yet. Just trying to figure what I need to fix first.
allisbred
Posted: 22 Mar 2018 at 8:37pm |
Ok-- thank you. Kevin
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 23 Mar 2018 at 8:07pm |
Sounds like alternator replacement is in order. One wire alternators do not belong on a tractor, use a three-wire. There's nothing wrong with the Delco if it's installed/working properly...
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 23 Mar 2018 at 8:31pm |
On my B i put an aternator on . To get it to exciet i put a nor open switch on .Crank engine and pull switch to on and it starts charging.Turn switch loose and it still charges untll engine stops .In nor open it will not run bat down when not in use . Works good for me.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 23 Mar 2018 at 9:06pm |
you could just put a smaller diamter pulley on the alternator. AIn't no way a tractors going to rev faster than a car !
