Delco SI alternator
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Topic: Delco SI alternator
    Posted: 22 Mar 2018 at 8:06pm
Have a tractor that sat for awhile and have to trip the relay to get the 1 wire alternator working every time the motor goes back to idle. Is the relay causing this issue or can the magnetic field be lost permently from sitting. I'm not a fan of these but, was already installed, I think they seem to draw some power when not in use.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:14pm
Delco SI alternators are internally regulated and don't have a relay. If you have a relay on one it's wired wrong.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:22pm
The 10 SI needs a higher RPM to excite and once output is established it will stay charging or regulating internally - no magnetism involved until electric flows - as not like a generator with residual or self exciting .
 If it's drawing power when off - bad diode in diode trio - replace that .
look on back and there should be a U shaped hole in back casting - just inside a bit is a tab - if you take a small screwdriver and touch case and that tab it should give you full output from alternator - if not internal regulator could also be bad
Edited by Coke-in-MN - 22 Mar 2018 at 8:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:28pm
No external relay, you would be correct, it is the regulator that I'm thinking about in the alternator. This tractor is new to me and has not been working yet. Just trying to figure what I need to fix first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:37pm
Ok-- thank you. Kevin
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 8:07pm
Sounds like alternator replacement is in order. One wire alternators do not belong on a tractor, use a three-wire. There's nothing wrong with the Delco if it's installed/working properly...
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 8:31pm
On my B i put an aternator on . To get it to exciet i put a nor open switch on .Crank engine and pull switch to on and it starts charging.Turn switch loose and it still charges untll engine stops .In nor open it will not run bat down when not in use . Works good for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 9:06pm
you could just put a smaller diamter pulley on the alternator. AIn't no way a tractors going to rev faster than a car !
This page was generated in 0.087 seconds.
