delco alternator with steering pump
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: delco alternator with steering pump
    Posted: 16 Jun 2024 at 4:29pm
is there a delco alternator case , shaft , coupler , combnation for the power steering pump for my series 1 d17d
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 5:43pm
There was a Delco alternator with a vacuum pump mounted on the back that was used on Diesel Trucks..... Dont know if the vac pump could put out pressure, but the alternator must have had a drive shaft thru it to drive the pump...
Edited by steve(ill) - 16 Jun 2024 at 5:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 6:39pm
There was an early Corvette system similar to what you want, but that may have been a generator not an alternator.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 9:07pm
My Grand Pappy had a 1956 Chrysler Windsor with a generator and power steering pump.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:44am
I have seen the exact setup mentioned but not on a tractor. It was in sprayer carts used on golf courses, and cemetery maintenance. I think they were Ransomes, or Jacobsen built carts. Also thinking the same thing on an older Cushman "Truckster" from the 1970's.
Thinking back none of these were hydrostatic driven machines. Sprayer carts had centrifugal clutch with reverser drive, and a manual transmission in the "Truckster".
That's All Folks!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 3:12pm
Get your generator rebuilt and you are good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:36pm
we need b&b to chime in ,    i would not be suprised if it was a matter of putting the right delco numbers together,    if a armature was somwhate compatible i think i could weld up a case and machine itto bolt the pump on.   i have not checked to see how many amps the geny is,   i want to run the head lights on the grill and the series4 lights on the fenders a rear work light and two lights on the baler one in the back and one looking at the pick up .  all led    after all these years good lights is a treat   big change from the 6v on the old wds  the coleman lantern was better
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 9:26pm
Many old trucks had P/S pumps on the rear of a generator.
Never saw a p/s pump on an alternator in person.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2024 at 8:12am
Hi Mike!
Sorry, coming into this kinda late. I've been busy and only been popping in here a couple times in the past few days. Anyway, there is an Alternator on the market that is designed for power steering. Its made by Mitsubishi for Forklifts. I have one on the shelf for my Forklift customers, but they are super expensive! Yer' talkin' about $715. for one of those puppies. I can build a Delco 1100345/1100440 12V Generator with long shaft for pump a bit cheaper at $450. if you have a unit to rebuild. Same Gennie that came on a WD45D, D17/19 Diesel w/p/s. I can send a pic of that Misti Alternator if your still interested.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2024 at 11:02pm
thanks steve i should have 2 good genys with pumps on them do you think that it can keep up with all the work lights and headlights i want to run
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 8:06am
Just let me know what accessories your going to use, and I'll figure out the amperage needed to do the deed. I'll have my rewinder wittle an Arm up to handle output. Shouldn't be a problem. I can design our own output. I'll then mate a VR to it that will handle the current usage through the system, handle the accessories and keep the Battery happy as well....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 9:32am
HUD... you said all the lights are LED.... Mosts head lights are 2-3 amps on the LED version.. As STEVE said, you need to know the SPEC on each ... but if you ASSUMED 3 amps each and 8 lights... thats 24 amps. ( you might be closer to 16- 20 amps)...Good generator would do that , but thats a good load on a 30 amp generator.... be nice if it was wound a little bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 9:39am
i am going to spend a lot of money on my tractor so i will gather more info and we can find out what the full load will be may be we will be ok with all this led stuff .  i not  i will have you build one that will kick it in the butt
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 9:50am
another option ( if there is room) is to mount the steering pump directly below or above the alternator and run a belt from the alternator to the pump...... the MAIN belt drives the water pump and alternator..... but you have to have room on the side of the tractor..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 11:08am
I've built Generators for our hotrod customer's up to 65 amps which is pretty stout for a Gennie. Some of our customer's do not like the look of an Alternator on their Flathead's or inlines, so I build them a Gennie that will handle their creature comforts, yet keep the "old time" look. I've built a couple one wire Generators in the past as well where I could squeak up to 100 amps out of them on the 881 machine where a VR isn't neccessary because of the built-in regulator I use. Those particular units are all custom built, and for a Tractor, they are quite a bit of dough to build. The problem in this case would be the long shaft Armature to drive a pump. The Alternator components I need to use to build it like a one wire Alternator inside will not work with the long shaft Arm design. It's probably a good thing anyway, because with the drag of the pump on the rear of the unit would probably in my opinion overheat the unit, and a failure would eventually occur. When building a higher output Gennie, I always use an open front chassis and a fan when possible for keeping the internals cooler...
Steve@B&B
