Deere Before Allis:
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: Deere Before Allis:
    Posted: 14 May 2025 at 6:49am
3020 Deere. Really good condition but main hydraulic pump has taken to seeping. Works fine but is needing resealed. Owner purchased a brand new one as doesn't want to have problems later on as tractor is a working unit. Multi year loyal customer so I won't tell the family "No" to any work they need. Pays well too in cash at job completion:
Parking spot in the shop:
Steer axle removed for clearance:
Leaker:
Damned pump is heavy so used transmission jack to remove it from the tractor:
Owner ordered brand new rear tires and tubes and they will arrive at the shop this afternoon. Old dry rotted and cracked originals are full of calcium so I'll need to see if that gets replaced or not. I'll blast the rims clean and paint them up before remounting the new tires.
This job will partially fund other projects going on around the "hood".
That's All Folks!
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 7:48am
Whether you like green paint or not those 3000 and 4000 series deeres are some good looking tractors
Edited by thendrix - 14 May 2025 at 7:48am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 8:16am
every thing we work on here is green or red  as they were the big dealers hear in the 60s 70s 80s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 12:25pm
Green, blue, red, yellow, orange, really doesn't matter much to me as they all pay in the same shade of green which does matter.
New pump matches old near exact and is Deere supplied. Old pump on left fresh from solvent tank:
After moving fittings over with new sealing rings:
Fasteners are in solvent tank degreasing so will slip it back together after lunch and wrap the job tomorrow morning. Greasy slimeball on the underside, (oh wait, that's meWink) as the front seal really started leaking and throwing last year during harvest; or the story goes:
That's All Folks!
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 1:16pm
If that new pump has a serial number plate, you’ll need to time it to the engine to prevent vibration in the hydraulic system. Outer dimple on the pump shaft goes in the 1:00 position when engine is at TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 3:18pm
Thank you, I've never heard that in the past. Both the old, and new pump have holes, or marks on the input shaft. I didn't know what they were for but was planning to align the new to the old before slipping the unit together. The engine has not been rotated but I will ensure the engine is on TDC now knowing.
Thanks again.
That's All Folks!
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 3:59pm
Is the new pump "Brand New" or a factory Re-Man? Just curious how proud JD is of it, $2K? Been helping a friend refurbishing a NH 2450 swather/haybine. The header is hyd. driven and brand-new (NH) hyd. motor was $2,800 with 6-month warranty and factory (NH) Re-Man was $2,100 with a 2-year warranty. Went the cheaper route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 4:47pm
I don't know myself but will ask. I know it came from Sloan's through my cousin I help out during harvest as he receives a discount.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 10:00pm
Brand new pump supplied through Deere. I'm asked to not reveal price as a personal relationship is at play, but it is close to a reman unit in the aftermarket.
As prior poster mentioned, timing is important and I'm grateful this was brought up. The pump is shipped in the one o'clock position in the box so will align the crankshaft timing marks to correlate and slip it together tomorrow sometime.
Owner is dropping the new tires and tubes tomorrow morning and doesn't want the calcium ballast in the new ones. I showed him the deterioration around the valve stem on one side and I may weld this closed and punch another through someplace else. Local tire vendor has beet juice and they'll install that for him.
Edited by Codger - 15 May 2025 at 6:41am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 6:36am
I ordered a manual for this tractor series this morning. It will get use as they do plan to retain the tractor for some time. Only piece of equipment they have that is gasoline powered, but it is liked, and has a bit of history with it in their family.
Hopefully get this wrapped up and loader reinstalled over the weekend. More of their stuff needs to come over for both service, and repair.
That's All Folks!
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 12:27pm
We had a 3020 gas, worse tractor we ever had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 12:44pm
Like people, there are both good and bad.
What specific problems did you have? Repetitive in nature, underperforming in tasks ask of it etc? This one I'm told has been a sweetheart and serves the purpose well. I have no experience myself so inquisitive in nature.
That's All Folks!
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 29 minutes ago at 10:33am
Delete
Edited by joe - 17 hours 28 minutes ago at 10:34am
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 28 minutes ago at 10:34am
That's quite a price difference, and sometimes, with reman, you actually get a brand new part, but reman pricing and warranty. I hope it performs well for him, but I'd think long and hard, even at $700 more, and only 6 months warranty. Reman can often be rebuilding worn out components.
