Deck for T818
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Deck for T818
    Posted: 24 Apr 2024 at 10:58am
Will a brand new simplicity 48 inch deck fit on my Allis T816?
Blue Skies and Tail Winds
                          Dana
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 6:10pm
That depends on what the new deck is supposed to fit.  What do you have for info on the new simplicity deck?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 6:48pm
Should be a tag on deck with id number. That would help
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 6:23am
Ok ill check
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 5:24pm
Hey MikeZ the new deck is from a Simplicity Regent
O/SIMPLICITY/2691456 is on the tractor, the deck has no tag he says but tractor model is 2691456.
Does this make any sense😁
Edited by captaindana - 25 Apr 2024 at 5:28pm
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 6:19pm
Is it a stamped or fabricated deck. My gut says it’s not going to work based on how the linkage connects on the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 4:24am
48ā€ FAB
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 4:27am
Ya see my T816 came with a 48ā€:deck and the fellow said he never had the deck running because of some ā€œpartā€ he didn’t have. I have my owner op manual coming. So if this new available deck wont work I’ll try to get what I have going again. Thing is this new deck is unused. Thanks Dana
Edited by captaindana - 26 Apr 2024 at 4:28am
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 6:31am
With enough time and torch gas everything is a bolt on. It’s probably going to be a lot of reinventing the wheel.  What part are you missing from the original deck?
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 6:34am
You should be able to download all the manuals from simplicitymfg.com. You will need the mfg number off the tractor. If you don’t have that number you can search on partstree.com by model number and it will show mfg numbers for that model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 7:05am
Your 818 decks main attachment is from front. Looks like that other deck is to the rear. Send me some pictures of 818 deck and I’ll see if I can tell what’s missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 1:18pm
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 6:22pm
I really don’t see anything missing
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 7:56pm
   When i get time ill have to mount it maybe the tractor is missing something.
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 10:31pm
The engagement rod probably is what is missing. It would run from the lever on I believe the left floorboard forward to the pivot on the left side of front mount on deck. It would pull the pivot rearward to engage the deck by tightening the belt and releasing the brake rod across the front of the center arbor pulley on the deck.  Clear as mud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 4:39am
Yes sir I understand that. Ill need that! MikeZ!!
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 6:12am
I’ll take a look in parts book for part number and see if have that rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 6:49am
#46 I believe is the rod. I’ll check see about having it
