DD motorgrader clutch
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: DD motorgrader clutch
    Posted: 17 Feb 2012 at 11:42am
Is the clutch in a DD grader the same as a D17 tractor? It looks like a D17, I can't find part # for the DD clutch. Thanks, Sam
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:06pm
Do  you have  d-17  diesel  or  Wd45 diesel.   ??   That should  answer  your  question.       Tony
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 1:11pm
DD should be a diesel and if so it should have the same clutch as the D17 diesel tractor of similar vintage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 1:32pm
Sam ! Wd45d  used  10"  clutch,  D-17  used  11" clutch.       Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 1:22pm
Your serial number can be used to find out the year it was made and that will tell you if the engine is based on the WD45 diesel or the D17 diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 10:57pm
It  is 262 diesel same as D17 and it is a 11" clutch and looks like a d17 clutch, just wanted to make sure before I ordered a D17 clutch. Tisco and A&I don't list one for a DD grader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 10:12am
Ordered clutch disc, throwout brg, and pilot brg for earily D17 diesel and they are what I needed. Series 4 D17 uses a larger diameter throw out brg. Thanks for the info.
