DD grader hydraulic pump gpm, press?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: DD grader hydraulic pump gpm, press?
    Posted: 30 Jan 2020 at 7:34pm
Ive got a grader with no engine, and the center section of the pump is busted. Found a 262 gas to put in, I want to know if parts are availabe for the pump. Its a hydreco 078178. What would be more helpful is the specs of the pump. I see surpluscenter has a couple hydrecos
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 7:52am
those pumps are only 12-1500 psi. acccording to the book. not a lot a pressure back then.  no specs given on gpm but 10-15 should suffice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 9:37am
Thanks Cal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 10:07am
Unit on my crawler is 40gpm but still less than 1800psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 10:09am
HDg6 is 40 gpm and relief is 1250 psi max
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 4:53pm
The pump used on the D is avaialble from Hydreco. I purchased a new one 3 yers ago, about $650.00 complete. I can look at it and provide a part number.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 8:13pm
Ages Cat
Is Hydreco still in business then?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 4:20pm
Hydreco is still in business.
Part number does not look right. It looks more like a spec no.
