DD 2-71 fuel pressure?
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Topic: DD 2-71 fuel pressure?
    Posted: 28 Oct 2018 at 8:04pm
Wondering if anyone knows what primary fuel pump pressure on a Detroit 2-71 should be at cranking speed ?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 2:44pm
I just remember if it was under 45psi running it was time to change filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 3:14pm
Believe that was running pressure, been looking for my 71 service manual, thought cranking was like 25, have a note somewhere.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 5:02pm
Cranking or running - on startup it's low - running 15 to 25 PSI seems where mine runs . depending on RPM
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:14pm
Can't see any pressure on mine when cranking (and it doesn't want to start) removed pump and ran on bench with a battery power drill that has three gear ranges. Tag on drill says 300,600,1600 rpm respectively. When I run it at 300rpm I get 10psi, at 600rpm 25-30 psi and at 1600rpm 60 psi (approximately) I don't know what rpm pump shaft turns when cranking but i see no pressure on gauge?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 9:25pm
is the pump turning?  I had one that the small coupler on the driveshaft to the pump had split and fallen off...nothing worked then
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 6:07am
The other potential is the blower drive shaft splines sheared. Is a common problem on the older high hour engines. With the pump off spin the engine and see if the drive turns. If can get pressure from a drill running it then look elsewhere.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 1:47pm
I had the splines go on one of my older Detroits. Fortunately it was the splines at the pump end that were gone. I was able to buy a shaft with old (finer) spline on the end going into the blower and the new style (bigger) spline on the pump end, this way I didn't have to disassemble the blower to get fixed up.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2018 at 7:11pm
Thanks for all the info. Will be checking that when I get back to it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 6:44pm
Did get a new pump from pro diesel. Installed, primed, and started right up. Running about 70 psi when throttled up. Dis assembled old pump. Just doesn't look that worn to me and relief valve looks ok too ? Will try to post a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 5:10am
Problem with a Positive Displacement Pump as these is they live in thousandths of an inch of tolerances. Small scratches that lead to even smooth wear grooves end up allowing the fluid in this case fuel to bypass around the gears when building pressure. Is what occurs with most hydraulic pumps, look fine but have developed a few extra thousandths of clearance and can no longer build or maintain pressure.
