david bradly wagon colors
mnhorseman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnhorseman Quote  Post ReplyReply Direct Link To This Post Topic: david bradly wagon colors
    Posted: 01 Jun 2011 at 7:49am
does any one have a picture of a david bradly flair box wagon with right colors and mine has hub cabs were they stock.... or a picture from a sears book where they were sold thought it would look nice being pulled my 33 picker in parade's
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:51am
Here is one I saw on Google. it looks like and is the same color as the one my neighbor has. Hope this helps.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:55am
Dad's is green (close to Oliver) with red or orange wheels and yellow letering(I mean lettering). I don't have a pick.
Edited by Lonn - 01 Jun 2011 at 11:46am
Wink
I am a Russian Bot
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 9:31am
   Our barge box was originally painted dark green on the wood and wheels. The gear, hubs, lug bolts, and metal hardware on the box was red. We redid it with Oliver green and IH red. As close to original as you will probably get.
Edited by Rfdeere - 01 Jun 2011 at 9:33am
http://www.rumelyallis.com
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 12:22pm
As I understand it, the wooden David Bradley flair wagons were painted the dark green that was traditional for grain wagons.  When the steel flair body was introduced, they were painted green for a year or two, and then after that they went to a red color that was similar to Massey Harris red.  Mine is steel, and what's left of the paint is red with white or yellow pinstripes.  BTW, I believe that the all steel flair bodies were built by Horn Mfg for DB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnhorseman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 12:23pm
the one i have is all metal sides did david bradly make a metal side one and the hubs has have a db on center cap and willy knight caps on 2 can not read last one
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 12:33pm
According to this page:  http://wellssouth.com/blog/?p=207  there were several different versions of the DB flair box.  If yours has steel sides and a wooden floor, then it was likely sold after David Bradley had switched to Electric Wheel Co for their supplier of wagon bodies as detailed in the above link.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 12:41pm
Dad's is steel and green.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnhorseman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 6:29pm
i bought this about 15 yrs ago at a auction It has green under frame an la redishish looking top all metal even floor, what throws me is the hubs on wheels this one had hub caps covering centers with the centers being d b on one and willy knight on other two could it be a old car frame undercarriage...... Any body got a pic of just the running gear
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:07pm
I don't know if these colors are accurate, but the wagon was beautifully done.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 10:32pm
GBACBFan:
You're right, that wagon is flat out gorgeous!  I'm guessing that it has a wooden floor, and by the decals it is a later model.  The running gear is the same as what is under my all steel DB flair wagon, but mine ain't near that shiny ;-)
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 11:02pm
Ours was a steel body and all red with greenish yellowish wheels. It had a wooden floor.
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 4:45pm
The wheels are the right color. You can mix 1 part of John Deer yellow and 1 part of John Deer green to get the correct color. I painted my David Bradley frame New Holland red.
