Daughter's Family Christmas Present:
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: Daughter's Family Christmas Present:
    Posted: 6 hours 33 minutes ago at 1:13pm
We really don't do much as far as presents and such except for the little ones. However, as a family we help each other out a lot. Photos are of my daughter, and son in law's house with a block shower in the basement. Having three females, and a single male in the household, you can relate to how important a separate shower area can be at times.....
This area was painted/coated with something that paint strippers won't touch. Three different stripper types were tried as per label directions concerning coverage, and dwell time. The gray lifted fairly easily, the white with great effort and multiple applications, the yellow, not a chance. In the photos, yellow is the base applied to the block; at some point it was repainted white, and then another white coat, then ultimately the gray color which would readily peel if sprayed with hot water in places.
I elected to blast the shower area clean using a 20-40 blend of coal slag media. This is a fine grit but aggressive but the hope was to not profile the block terribly to render a smooth and consistent finish. A lot of covering of the toilet, vanity, medicine cabinet and electrical outlets with "Gorilla" tape to ensure a clean parting line when peeled off. The window sash was removed from the opening and an evacuator fan placed into the opening. Process when quite well really and very little dust in the finished basement area to clean up. There was enough room for my small blast pot, and 350# of media and still allow room to work.
Starter photos:
Job as started after they had expended several hours labor and materials:
More following.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 18 minutes ago at 1:28pm
This is after starting after it with about 60psi to crack the top surface open and measure progress:
The gray, and the white color readily washed off the surface. Forgot to mention a piece of 1/4" plywood was affixed to the ceiling to not destoy that and the coating went right up to it.
The yellow was found to be able to crack at the lower pressure but a lot of media expended to do it. Pressure was cranked up to 100psi which readily busted through it and really didn't profile the block hardly at all. I cleaned the yellow off, and then moved to the floor. Didn't photo the bare block at this point but did video close to the finished job. I'll attach that later:
I was able to clean a good portion of the floor but under the paint was a rubberized type material that wouldn't blast clean. We will get the weed burner after it to soften, then scrape up and I'll follow with more blasting for a good "tooth" for the new epoxy base and topcoat to adhere to. The drain you see was a ball of rust as was the grate:
More in a bit.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 3 minutes ago at 1:43pm
After initial blast and slight cleanup:
And pretty much as the place was left. Easy to see when the masking tape holding the plastic tarps down was peeled away, the gray and white colors came with it but leaving the yellow. That rubberized crap on the floor readily softens with heat so I'll get back over there towards the middle of the week.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 19 minutes ago at 4:27pm
Interesting,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 5 minutes ago at 4:41pm
Yes, it is interesting and rewarding. I depaint and metal prep a lot for automobile restoration shops, and historic home restorers locally.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 41 minutes ago at 5:05pm
looks like it cleaned up well... are you thinking the yellow was epoxy, or  some type of ceramic ?  I have never tried to blast epoxy.... I see a big difference in ORIGINAL Enamel or equipment and REPAINTED Enamel on equip.. Some times the ORIGINAL dont blast off east !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 38 minutes ago at 5:08pm
I believe an epoxy. Home is mid 1960's build and this stuff was tough to crack with a very slick face finish.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 35 minutes ago at 7:11pm
I did these last fall. First Chevy Blazer sold, (documented) in the Peoria, IL area for the 1969 model year:
Don't think there is a single fastener untouched and or replaced in this thing. Many NOS parts and many new Taiwan stampings that have been massaged and bettered for proper door gaps and alignments. Vehicle is being assembled at this writing and looks better than new.
I don't have owner's permission so not going to post the vehicle but most likely will later.
I do the same quality on tractors but it can get expensive as billed by the manhour.
That's All Folks!
