dash throttle to console throttle on 8010 |
Post Reply |
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
Posted: 24 Nov 2017 at 12:54pm |
I bought an 8010 last year with the dash throttle. I'm working on converting it to console throttle. I found the console throttle and linkages at a salvage yard and I am getting ready to order the cable. after looking at my 8050 which has the console throttle I noticed that the bracket that the bell crank fastens to on the 8050 is not there on the 8010. there is also a fork bracket that the throttle cable hooks onto that is missing as well. Will I need to fabricate these and weld them on? I'm just curious if others have had this problem in the past and what has been done.
Also, I assume I will just abandon the traction booster? I only use this tractor for planting and baling. Thanks in advance. Derek
wekracer
I wanted to post an update in case anyone has to do this going forward. I used my 8050 as a pattern. I had a local machine shop bend the bracket for the bell crank and I made the cable mount bracket. It was a pain in the but getting it all lined up correctly and welding it in the cab, but it works like it should. I should also add that I got the throttle linkages from Northside salvage
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
Nice conversion! Wondering if you have the ambac pump or the roosamaster pump?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8004 |
Didn't all 8000's have Ambacs?
wekracer
I’d have to go look but I believe the 301s had the Roosa even in the 8010. Our 50 and 70 both have ambach
ALLISMAN32
Bronze Level Joined: 13 Mar 2011 Location: Hillsboro, IN Points: 199 |
Do you run the remote outlet relocation levers in all 3 8000 series tractors? I think I looked at the ones in your 8050 when I was there. Could you post some pictures of those?
wekracer
Yes. We have them in all 3. I will have to remember to take a pic tomorrow. That’s the only negative on an 8000 series is the remote lever location.
Peterson
Early 8010s had the roosa. Later ones had the ambac.
Post Reply | |
