Dang Varmints!!! |
Page <12 |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 10 Jun 2022 at 9:34pm |
Yes, VarmitCong
I am still confident of this;
KJCHRIS
Posted: 11 Jun 2022 at 2:08am |
I've used mice n rat bait boxes and the bait for them. We had that issue several times in a back lot that had low use cars & pickups there over the winters. After rewiring 3 or more vehicles every spring it made sense. I don't know if it's squirrels, rabbits, rats or mice and really don't matter. Not sure why but they chewed on Chevy & GMC left the Ford & Dodge alone. 1 of the mechanics said GM used a grain based oil for lube on the wiring ( not sure but ?? ). I fixed some 2x6 scraps to them after 1 got carried over near a fence, looked like raccoon prints.
Get some bait boxes and keep them baited. IF your garage is full it may need a box in there also.
KJCHRIS
Posted: 11 Jun 2022 at 2:10am |
B T W, I use the boxes at farm bldgs starting late summer thru winter. Helps keep critters out of bldgs and away from the bins. I've no dog or cats so bait not any issue.
fixer1958
Posted: 11 Jun 2022 at 7:20am |
There was a 2019 Tahoe that came in the shop a couple of months ago that had an freon leak. 1234YF freon is some expensive stuff. $500 for a recharge just for the freon. Stuffed a little in it and it was coming from the right rear fender well. Took the inner fender out and a rat chewed up about a foot of aluminum line and one little bitty hole in the high side line. Must have gassed his ass because he was still there deader than a hammer.
Replacement from the dealer was 4K for the line assembly. I found splice fittings just for AC aluminum lines. Worked really well. Never used them before. I have seen rats chew up a lot of stuff but not aluminum. I have pics on my phone but don't know how to get them on here.
shameless dude
Posted: 11 Jun 2022 at 8:23am |
squirrels got to one of my trucks last year, still trying to get it going, put moth balls, rat/mouse bait, in the engine and cabin areas, frebreeze sprayed in there seemed to work the best! good luck on yours!
plummerscarin
Posted: 11 Jun 2022 at 9:30am |
Have tried all that and the TomCat bait on the tried and true spring mouse trap is the ultimate solution for me. The downside is the regular check on my trap lines.
I set them on the floor of the cab Interiors as well as around the building. Caught 6 in the pickup since November |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 11 Jun 2022 at 12:04pm |
The soy in insulation has been close to 30 years I think. Because that is when critters started looking for wires to chew.
The vineyard had a new 45 HP New Holland tractor the pack rats packed the under hood area full 2 years as it sat from Nov to Feb. After the first time there was always rat bait out. Bait helped but did not stop them, but nobody went in the shed for a month or more at time that time of year. So T since you don't have time for in person measures, I think you will need bait and moving the "bird" feeders as far away as you are allowed.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 11 Jun 2022 at 12:12pm |
I guess if I can secure the bait so it stays put I’ll do that too. Sure don’t want the dogs to chew on it. The one got into it several years ago, caught her right away, and she still barely pulled through.
The one car they got to is a daily driver! |
Page <12 |
