Dad's 45 sputters...
Buckyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Topic: Dad's 45 sputters...
    Posted: 13 Jul 2019 at 10:21am
We have been trying to get my dads WD-45 to run smoothly for a while now and we've eliminated things like the points and coil and so on as issues. We just got a new carburetor and that didn't solve the problem either... about a month ago we tried replacing the seals on the manifold as well and with all that we still have a tractor that just doesn't run smooth and seems to have a touch less power. Dad and I are both stumped... Anyone have any ideas??
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 10:26am
Have you done a compression test? Does it run good when cold, but begin to sputter as it warms up?
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 11:45am
Does the 45 sputter under load or giving more gas to increase engine rpm?  The cause could be the neck it the fuel bowl has something blocking the full flow of fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 3:16pm
disconnect gasline at carb, get bucket, open sediment bowl valve.
does gas drain as a steady stream, very fast for at least 1 gallon ?
If so, not a 'gas delivery' problem..maybe carb setup
If not so, sediment bowl needs to be totally disassembled and cleaned,also check gas tank.
There could be a sliver of 'something' plugging the hole 'somewhere'.
With 'Troy' ( D-14 #1), a sliver of yellow plastic was in the sediment bowl where it threads into the tank ! Yellow....hmmm... spout of plastic gas can !!
Jay
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 7:55pm
On my Grand dads WD, it would start and run fine-for about 5 minutes.  Then it would die like you shut it off.  It had sediment floating in the gas tank and as it ran it would get sucked into the screen area and shut if off clean.  Removed sediment, end of problem!
Greg Kroeker
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 8:14pm
I would start with the simple things.
How are the plugs (don't use Champions!) and plug (and coil) wires? How about the distributor cap? Try starting it in the dark and look for misfires.
Does it run better with the choke partially closed?
As Jay suggests, check gas flow.  Check to make sure gas tank is vented. Ethanol gas can really screw up the fuel system.
Try removing the air filter hose and see if that makes a difference.
Edited by WF owner - 13 Jul 2019 at 8:19pm
Jaybird14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 6:52am
My 1951 WD has sat for about two years and is doing similar things.
She will start and idle fine but when i add power she slowly starts to sputter and run like crap.
fresh gas is in.
I've cleaned the carb and sed bowl. flushed the fuel line.there was crud in the tank partially blocking flow.
 new points and condenser.
new plugs .. but they are champion.. can they cause this much of a problem? if yes what brand is the "best"?
I did notice my idle screws and main flow screw on the carb don't do anything until they are closed . ??  do i still have a fuel flow issue??
i am going to mess with here today and i will let you know what.. if anything.. happens.
Jaybird
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 6:55am
I have not checked the valves yet. if it is running great at idle but sputters at a working throttle level could it be a valve issue?
thanks!!
i can turn the wrenches but i am hoooorible at diagnosing!!! lol
Jaybird
Edited by Jaybird14 - 14 Jul 2019 at 6:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 7:33am
thanks!!
Jaybird
That sounds like a fuel issue. There's a chance it could be electrical - coil or points or condenser - but I'd look at fuel flow first. Valves could be set too tight if it doesn't show up until the engine is warm, but if it ran before and the valves weren't monkied with, I'd put them lower on the list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:06am
would it be worth getting the autolite 303 and swapping out the champion??
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:21am
You said you eliminated the points and coil. What about the condenser?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:15am
I’m sorry I’ve done the condenser not the coil.
The new Autolite plugs did not do it.
There is plenty of gas flow when I disconnect at the carb and let it flow. The carb adjustment screws have no effect until closed.
Edited by Jaybird14 - 14 Jul 2019 at 1:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:29pm
You really need to start your own thread To get specific comments on your issue. My comment was for the original person who started this thread.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:32pm
done
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 5:29pm
I never did check the sediment bowl and I've seen at times that it doesn't look so clean so I will investigate and possibly try draining and cleaning the fuel tank as well. Maybe I just need to get a new screen and bowl altogether??🤷‍♂️
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 8:30pm
New screen,,,,,,,yes.  New bowl,,,,,,,,not unless the old one is cracked or has a chip(s) out of it.  And a MUST, a new gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 10:07pm
I took the entire thing off the tank and cleaned it with carb spray.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 10:19pm
I believe the bowl itself may have some gunk or something in it. Is there anything special I should be using to clean that out? I haven't taken it off I'm just wondering if I need to round up anything extra when I get to taking this stuff apart...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 10:20pm
I've also found an old "farmhand" tractor-mounted rake that we used on dads tractor many years ago. It's more of a window tipper than a rake but anyways I have no idea how it would've mounted on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 6:59pm
To my great frustration after going and cleaning out all the junk out of the sediment bowl and reinstalling with a felt paper gasket it leaks a ton and the tractor runs much worse...is a gasket all it takes to finish the deal?? I'm nowhere near convinced...
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 7:30pm
All mine have a cork gasket. That may not solve your problem but it should stop the leaking. Where are you in WI?
Edited by mdm1 - 17 Jul 2019 at 7:31pm
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 7:41pm
How much slop is in the distributor shaft? Are the advancement weights in the distributor free or sloppy? Never seen a paper gasket for the bowl only cork. Don't think paper would have enough give to conform to the glass
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 7:56pm
Should be a cork or neo-cork gasket.  1/8 in. thick.  New ones are available at my local Napa.
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 8:11pm
The sediment bowl on my WD45 had some old gasket material stuck to it that made mine leak.Check and make sure the gasket surface is clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 7:07am
Did you adjust the valves?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:07pm
Dad says the tractor runs fine now that I put in a new gasket and suggested than any further sputtering could be due to old gas. So I will try some "heet" and see if that does the trick. I was wondering if anyone knew how a Farmhand window tipper would mount on a wd-45?? We have one that dad doesn't remember the configuration of but knows it was always mounted on the right side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 5:57am
Try Seafoam. I'm not much for additives or snake oil, but I have had very good luck with Seafoam cleaning up the fuel system, it it's not too dirty or plugged up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:15am
So after posting that last message last night I ended up driving dad around for a couple of minutes on the tractor and showing him the problem...I can also give a little better description to what's going on. The tractor will herky jerky drive along the road at pretty much all amounts of throttle in a very uniform jerking pattern. I think it could be the timing but I really don't know what it could be. Dad did realize though once I drove him around on it that something is definitely goofy.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 9:48am
Not sure about your description, BUT it sounds like the dist. is advanced to far. Try setting it WITH engine running. ---- as you move it back and forth, pick the best sounding spot and snug down the clamp bolt and try that.---may take a few tries to get it fine tuned but they are picky on the set. ---I have one that I never could get smooth, close but still a bit choppy. thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 9:53am
Before you do anything with the timing, check the point gap. If the dwell is off three degrees, the timing will be off six degrees.
This page was generated in 0.075 seconds.
