DA 385 Planter Questiosn
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: DA 385 Planter Questiosn
    Posted: 22 Jul 2023 at 2:02pm
Hello all,
Recently purchased a DA 385 planter (6 row).  I planted about 60 acres with it this season to see how it works, and overall, it worked great.  I do have a few questions I was hoping you could answer.  I do have the operators manual, and the parts diagrams, but the questions I have are not in there.
1. Did anyone make covers that fit over the PVC seed drain in the hopers?  It seems to mee that they hold a lot of seed that would work better in the hopper, than in that little PVC extension.
2. I need to install new seed pads in the hoppers.  The operators manual does not seem to show this, so I am looking blindly at it.  The replacement foam pads have adhesive on the edges, but I cant tell if the plastic covering of the foam pad goes under the aluminum trim ring, or on top of it.
Thank you,
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2023 at 6:38pm
1)
We put duct tape over openings to keep seed out. Has worked well. Got 4 seasons out of that so far.
2)
We have the trim rings over the pads
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2023 at 6:44pm
Glue the seed pads to the plastic or aluminum housing on top off the adhesive. Glue the wear ring to the seed pad top. Use a piece of wax paper and install a seed disc and tighten the hand nut to squeeze everything into place and let dry at least 24 hrs. 3M glue brown or yellow weather strip adhesive. Remove the seed disc probably with a sharp knife to unglue the seed disc before planting. Make sure it turns by hand !!! with drag on it.
Edited by DrAllis - 22 Jul 2023 at 6:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2023 at 8:15pm
Great idea with the duct tape.  Thank you.
Dr. Allis, I  appreciate your thoughts on the adhesive.
Thank you both
John
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2023 at 2:13pm
The origional seed hoopers did not use the galvanied wear ring - it was a product improvement campaign on the early ones.  The ones with the screw type dept adjustment.   We improved the performance by upping the blower speed by running a ground wire from the blower motor black ground wire- splicing into it and grounding to the planter frame - don't understand why but one can actually hear the fan increase speed. Worked on the old 78 air units as well. We ran the medium small seed disc - starts with part number 715... We added the tickler brush from the beet or sorghum kit - the White planter tickler brush works well. They can be left in for soybeans but are mainly for corn - it helps eliminates doubles in light seed.  You can see the kit in the parts book. We also ground a "V" into the outer edge of the seed discs to allow fines and other build up to exit with out breaking the air seal and loosing pressure. The V was about  7/16 on the outer edge and V'd just to the edge of the wear line on the inner side. We also found 1 blower per only 2 units really helps as we need 2 WC " of pressure on the center drop plates.  We also poked a hole in the wire blower screen so as to put a tube in  to blow the build up off the squirrel cage fan blades. Still know the location of the 12 row that came off Loretta Lynn's Farm.
