D2900 head advice
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: D2900 head advice
    Posted: 23 Mar 2014 at 7:25pm
Is there any hope for a cylinder head with damage in the injector seat area where the copper washer goes?  Could it be machined down and had a small sleeve or spacer installed?
I should mention that it has already been surfaced and had all new valves and seats installed.  Cry  Id rather not explain whyDead
Edited by CAL(KS) - 23 Mar 2014 at 7:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 8:52pm
Has to be awfully bad to not seal with a new copper washer installed the correct way and bolts torqued up tight. There used to be a tool to dress those up if they got damaged, but I don't have one.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 10:15pm
I have taken a endmill and turned it by hand to smooth it up.   MACK
BradRisen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradRisen Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 10:58pm
Dr.allis,would a " counterbore tool" like machine shops use, work to re- surface the area around the injector? I have a set in my shop that has a hole in the end of each counterbore ,with a set screw , I just turn out the size of the pilot needed to fit the hole on the work piece , in my turning lathe,insert it into the end of the counterbore, tighten the set screw ,and it is ready to use.
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 11:30pm
Like Dr.Allis said copper is very forgiving, if you do machine it too much, the injector tip can hit the piston + you said head has been surfaced, so be careful.  GOOD LUCK
This page was generated in 0.111 seconds.
