D2200 service manuals
615_259 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Topic: D2200 service manuals
    Posted: 21 Jan 2020 at 8:17pm
Hi all,
Looking for a good source. For a complete manual to rebuild the D2200 engine.
Just acquired a 615 backhoe/loader with a broken rod and a hole in the block.
Tractor came with a spare block and another complete long block,so I should be able to end up with a complete motor.already received the owners manual and the backhoe manual from jensales but want to make sure I have the proper engine manual.
Will be looking for parts and gaskets so any recommendations on sources would be welcome.
Thanks in advance
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 6:33am
Minnpar for a start on SOME gaskets, internals I cannot even guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 8:09am
Thank you
I will look them up
Any insite on a good service manual
My plan right now is to get the motor out and assess the damage
And decide the best way to proceed
So a manual that addresses engine removal would be helpful or some forum experience of what needs to be removed,
The loader frame makes things tight
Jeff
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 9:31am
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 9:41am
Contact Kevin @ Illini. He advertises on this site.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 9:05am
Thank you all for your replies.
The fine people at jensales took the time to make sure I got the correct manual.
Let the teardown begin
This page was generated in 2.031 seconds.
