D21 fuel smoking |
Post Reply |
ACman75
Bronze Level Joined: 20 Aug 2015 Location: Florence AL Points: 176 |
Posted: 2 hours 39 minutes ago at 9:50pm |
So dads d21 we’ve been working over last few years and finally got it out and running it some,But it is smoking some. Heavier under more throttle. Not oil smoke though. Smells like fuel maybe. Could it be timing off a little. We bought this tractor “with motor built already”. Had a time ever getting it to crank first time until we figure out it was 180 on timing marks. So it’s hard to use timing marks.
Also it will pop a little out of exhaust some times if you rev it up quickly. Also we had injection pump built by a local shop. Could it just be timing still a little off causing the fuel smoke? Edited by ACman75 - 2 hours 38 minutes ago at 9:51pm |
Orange Level Access Joined: 12 Sep 2009 Points: 20260 |
D-21 engine injection pump (if that's what it is) shall be timed at 34 degrees BTDC. What are you timed at ?? If you think a D-21 is smoke free out the exhaust pipe, they are NOT. Valve lash needs to be adjusted to .017" COLD on intake and exhaust valves.
Edited by DrAllis - 2 hours 20 minutes ago at 10:09pm |
Post Reply | |
