D21 and 210 Ring and Pinions |
lussetto
Joined: 05 Nov 2010 Location: Bridgeport, NE Points: 63 |
Topic: D21 and 210 Ring and PinionsPosted: 10 Apr 2016 at 10:02pm |
Is there a difference in ratios between the D21 and 210?
Greg
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5206 |
Posted: 11 Apr 2016 at 6:16am |
yes, the 210/220 is 3.70, D21 is 4.11 I think.
Posted: 11 Apr 2016 at 9:16am |
210-220 pinion gear has one more tooth for strength/durability and then they slowed down the larger final drives to essentially come up with the same axle speeds as a D-21.
lussetto
Posted: 11 Apr 2016 at 11:45am |
Thanks for the information. Got both the D21 pulling tractor and the 210 donor apart to swap differentials and they both had the same ring and pinion. Just wanted to make sure.
Greg
