D21 air cleaner asembly |
whatscooking
Topic: D21 air cleaner asemblyPosted: 08 Apr 2026 at 11:30am |
The cleaner that is in my D21 obviously isn't correct. Anybody have one? I have one that is too large to trade.
whatscooking
Posted: 08 Apr 2026 at 5:35pm |
Think 70253653 is the part number. By chance is it anywhere close to a 190?
Don Jr NY
Joined: 11 Sep 2009 Location: Waterloo NY Points: 378 |
Posted: 09 Apr 2026 at 4:27am |
A 190 air cleaner is the same size as a 200. The one in a D-21 is bigger and the same as the one in a 220.
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1738 |
Posted: 09 Apr 2026 at 8:48am |
Ar you needing the filter canister
phil
Posted: 09 Apr 2026 at 11:31am |
I believe the turbocharged D-21's got a bigger air cleaner (70253653) and it was the same as the 210/220 tractors. Older series 1 D-21's that got the factory field installed turbocharger "KIT" would have had this newer/larger air cleaner installed at the same time the turbo was added.
whatscooking
Posted: 09 Apr 2026 at 12:02pm |
The air cleaner in there now is so big there is only about 7 inches to drop the dust bowl out, no way the filter is comming out.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9002 |
Posted: 09 Apr 2026 at 12:49pm |
Have you tried it? It's tight on my 220 but will cock and come out.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1128 |
Posted: 09 Apr 2026 at 12:51pm |
That’s the way na 21s were
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7643 |
Posted: 09 Apr 2026 at 2:48pm |
Sounds like you have the right filter assembly. It looks like a tight fit, but the filter will come out.
whatscooking
Posted: 09 Apr 2026 at 4:17pm |
I guess I dont know what I want. Have the tractor at a shop to split for transmission seals, ow and a couple other things. |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2494 |
Posted: 09 Apr 2026 at 10:06pm |
I think that there were three different 190 air filter configurations.
whatscooking
Posted: 10 Apr 2026 at 4:00am |
Can anyone take their grill off and take a picture of their Series two air cleaner?
whatscooking
Posted: 10 Apr 2026 at 8:59am |
I got a call about one. Really would help to see what a Series 2 setup looks l8ke.
SteveM C/IL
Posted: 10 Apr 2026 at 3:29pm |
About 6.5 inches from bottom of cup to front surround on my 220
whatscooking
Posted: 10 Apr 2026 at 4:53pm |
And the filter comes out? I guess that is what iam seeing |
SteveM C/IL
Posted: 10 Apr 2026 at 4:58pm |
You need to actually try it before saying it won't work. The filter is smaller in diameter than the can so it has room to tilt and come out.
Mikez
Posted: 15 hours 60 minutes ago at 9:06pm |
