D-19 |
JoeRepking ![]() Silver Level ![]() ![]() Joined: 02 Dec 2009 Location: Centrall IL Points: 271 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2011 at 9:38pm |
Has anyone put a 301 diesel in a d-19?? was wanting to do it to mine and wondering if it would work.
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
The local dealer has one. Its a fairly easy swap according to him. Id like to do it to ours someday.
My gasser is shot and i am contemplating the conversion!
what does it all take ?
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
I want to know too cause that's my plan. Either that or drag Dad's gasser 190 out of the weeds and put the diesel in her but that one needs a new hydraulic pump and the one bull gear got chewed up years ago from losing a bearing soon after hitting a deep hole in the field when I was moving round bales in 7th gear flying. Never go that fast in the field again. The heater/AC knobs in the 7000 series cab left an impression or was it a depression in my forehead.
Wink I am a Russian Bot |
KGood ![]() Orange Level ![]() ![]() Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
I,am probly giong to do it also from what I have gathered I need to gain 4 inches in frame maybe because it has the four belt crank pully. What I've heard is there is a little grinding involved for the starter and flywheel. The thing Ineed to worry about is power steering mine is out of a combine and has no pump on the motor so I have to get some hyd. pressure somewere. Other than that it bolt right to the bellhousing I'am not 100% sure on the flywheel clutch combo to use but I have both so I guess I find out when the time comes. Be nice to surprise some people at the pulls.
Il have to ask him again for more details next time I talk to him. I do remember him saying he used 190 frame rails (there a little bit wider). Hecut the 19 frame rails off at the radiator,because the 190 are about 1/2" wider so he bolted them to the outside of what was left of the 19s. He also used the hydraulic pump on the motor so it has live hydraulics.
Jess ![]() Silver Level ![]() Joined: 09 Nov 2009 Location: ND Points: 262 |
would be great to see a pic if possible
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1565 |
Unless you just want a 301, the 200 (2/3 of 301) has plenty of power for a D19 and frame will not need stretched.
why would it not need to be stretched??
The 301 is a little longer than the original 262, or so I've heard. The 200 engine is a 4cyl and is shorter than the 262.
Il have to check, but I dont think length was the deal with using the 190 frame rails, It was the width. The 190s are about an inch wider. |
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Joe how about a 433 out of an F3. Same as the 6080. Its 4 cylinder turbo. Sitting in my shop you can hear it run.
IG
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
I've always thought that a 433 T would be real neat in a D-17.
The 433 would still run into the same problems as far as width.
