D19 with alternator; Negative or positive ground?
Cmart009 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cmart009 Quote  Post ReplyReply Direct Link To This Post Topic: D19 with alternator; Negative or positive ground?
    Posted: 23 Feb 2012 at 7:10am
As the title asks, we have a D19 that we took the battery off of long ago, but we can't remember which way the battery goes back on. Saw another topic asking about a positive ground, but we're unsure of whether or not that applies to ours, since we have an alternator. We assume that it's a negative ground, but want to make sure.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:21am
Maybe Steve at B& B will chime in later. I've never been acquainted with a positive ground alternator. I think I remember reading  or hearing they exist, though not sure and I'm certain very few in number.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:21am
Welcome aboard.
Without seeing your alternator I don't know for sure but all the alternators that get installed on tractors around here are negative ground. You might post a shot of the alternator and we can tell.
Don
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 8:47am
   The D19 came from the factory 12 volt, positive ground, charged by a generator. If it now has a alternater, 99% chance it is now negative ground.
http://www.rumelyallis.com
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 9:19am
Match up the connector size with the posts. They ARE fat and skinny ON PURPOSE. But if backwards the alternator is instant toast. Though if in adding the alternator which is most commonly negative ground they didn't swap the battery cables, you don't know.
I'm not sure a positive ground Delco S-10 looks any different from the outside from a negative ground and my Delco alternator book says they were possible. Basically the dfference is where the forward and reverse polarity diodes are pushed in to the diode heat sink and then the polarity of the regulator.
An alternator often will generate without a battery, with the sense terminal connected to the output, and turned fast enough. Then you could check polarity with a voltmeter BUT some alternators self destruct in that mode or run up a high voltage and destroy electronics in the vehicle.
If you know the polarity of the ohmmeter function in your meter, you can check the output post of the alternator (disconnected from the world, and one polarity it should show a drop of two silicon diodes and be open the other way. You want the battery polarity so its open. If its digital and has an ohmmeter range with a diode check you want to find the diodes with cathode to the post for negative ground and anode to ground.
For a less sophisticated test you can use the battery and a lamp. Say a dome lamp, about 1 amp 12 volts. Connect ONLY one battery post, then connect the lamp between the other battery post and the connector (preferably the to be grounded post for safety). If the alternator (all other circuits turned off or disconnected) makes the lamp glow full brilliance the battery polarity is opposite that of the battery. The lamp will limit the current that would destroy the alternator diodes with a direct connection
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:02pm
Originally it was Positive ground with the Generator doing the charging chores. A Gennie will charge pos. or neg ground. If moving to an Alternator, most Alternator's are NEG. ground. Install it and wire it NEG ground... HTH
Steve@B&B
