D-19 traction booster
ACMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Topic: D-19 traction booster
    Posted: 06 Nov 2011 at 7:48am
We usually chisel our ground but have some low ground that is sod now and was not planted due to the wet year. I put the 4-16 s/c semi-mounted on, I have 4 weights on the plow, with fairly new points, loaded rears with one set of weights . The problem is the T-B seems to work too easy, the lever on the quadrant is all the way down . is there another adjustment? The plow comes out of the ground because of this.  Maybe I just need 3 instead of 4 lol   TIA Bill
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 8:02am
The linkage from big TB spring to pump needs adjusted. Adjust linkage until you feel spring pressure on TB lever going into top 2 notches.  MACK
