D19 timing
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Topic: D19 timing
    Posted: 29 Jun 2017 at 9:03pm
Just installed an electronic ignition on my D19. She has a little miss in her now. Moved the distrubotor around a little to see if I could get it close. Can someone please help me and tell me where the timing marks are on this tractor and what or how to time it with a timing light. My older Allis gals were easy to time using the flywheel but didn't see nothing on this tractor. Got the manual but it says nothing bout how to time it. Just looking for some advice.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 9:28pm
Could be a problem. They had a timing strip glued to crank pulley. Some came off, some had a notch on pulley to line new timing strip to. May just have to find TDC then measure to find 25 degrees BTDC. MACK
