D19 Serial Number.........
bincitybandit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Topic: D19 Serial Number.........
    Posted: 14 Dec 2011 at 11:28pm
Picked up a D19 at auction the other day................
Can't find a Serial Number so I can figure out which year it is.  I know it is supposed to be on the front of the torque housing, but I can't see anything there even after taking a wire brush to the flat spot.  Is there any other place to look?
ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21
MINNEAPOLIS MOLINE: U, U, U(NF), GB
JOHN DEERE: L
FORD: 871 Select-O-Speed
CASE: 600 Combine
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 11:37pm
on a D19 the ser.# is on top of the rearend under the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 11:46pm
Can't seem to find a number that jives with the Hotline book...........
JOHN DEERE: L
CASE: 600 Combine
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 12:15am
Like said above the 19 serial # is on the top flat spot of the rear housing just behind the seat mounting frame. Should be stamped in starting with D19 XXXX and if it is a diesel should be followed with a D. If it is an early 19 and has an aftermarket/homemade center link bracket it maybe covered by said bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:34pm
Ok, I found the number behid the seat, it is D19 2270.
According to the Hotline book and the S/N Reference on this site, it should start with a 1 shouldn't it?
So if 2270 is the number, what year is this tractor?
JOHN DEERE: L
CASE: 600 Combine
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:41pm
1962
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:42pm
Thank you.........
JOHN DEERE: L
CASE: 600 Combine
