D19 rim options |
CW2 Ryno ![]() Bronze Level ![]() ![]() Joined: 17 Aug 2020 Location: Nebraska Points: 55 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Jun 2023 at 7:35pm |
Aquired a D19 over the weekend that needs some attention, both rear rims are shot. What options are out there for alternate mounting to use a non spin out rim ?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22059 |
D-19's came with 15.5 x 38 or 16.9 x 34/18.4 x 34 rear tires. All three could be power shift or non-spin out wheels. Changing from power shift to non-spin outs or vice versa only takes all the hardware. The cast wheel center remains the same. There are thousands of D-19/190/190XT/200 or 7000 and D-21 tractors in salvage yards to get your parts.
Thank you!
Just to make sure you don't mis-understand....there is a 34 inch cast center and a 38 inch cast center. Changing from power shift to non-power shift is only a hardware change. You cannot put a 38 inch rim on a 34 inch center and vice versa.
Current size is 18.4-34, I’ll double check dimensions before committing
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88293 |
some discussion on size... and step up rims...
rtwfarm ![]() Orange Level ![]() Joined: 26 Feb 2012 Location: nebraska Points: 1324 |
Got what you need. 402-469-1738
Thanks all!
