D19 PULLING TRACTOR
wrbewley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Topic: D19 PULLING TRACTOR
    Posted: 13 May 2011 at 6:46am
I AM LOOKING FOR HIGHER COMPRESSION PISTONS, DOES ANYBODY KNOW WHAT I COULD TRY, THERE USED TO BE PISTONS FOR PROPANE MODELS, BUT I CANT FIND THEM ANYWHERE, ANY IDEAS?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 7:14am
Diesel piston, then have it machined to whatever compression you want. Diesel piston was about 16:1 compression ratio, so unless you are running alcohol you WILL need to do some machining
1968 D15D,1962 D19D
