D19 Propane |
190XTLP
Joined: 06 Oct 2009 Location: Jerseyville il. Points: 51 |
Topic: D19 PropanePosted: 01 Oct 2018 at 7:35pm |
Got a D19 that tubs n idles perfect till warm then will die at idle unless choke is pulled out quickly. Original Ensign system n regarding was rebuild with no difference
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled WC styled,220 |
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 01 Oct 2018 at 10:31pm |
"tubs"? Maybe water in the system that heats up and plugs the carb?
Allis Express participant |
190XTLP
Posted: 02 Oct 2018 at 7:07am |
Replaced filter...no water or dirt in it
Just won't idle when warm |
baverwolf
Joined: 24 May 2010 Location: SE Montana Points: 828 |
Posted: 02 Oct 2018 at 8:11am |
Possible intake leak that changes with temperature? I had a inline 6 engine in a pickup that had symptoms as you describe. It had a crack in the intake manifold that would open up when it got hot. Cold it ran fine. Get it warmed up and spray some carb cleaner around on your intake manifold and also where it meets the head.
Ben |
