D19 Project
Stu ECWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Topic: D19 Project
    Posted: 14 Sep 2023 at 5:09pm
I'm hoping somebody can save some run-around.  Thought it was a "real big" issue when I couldn't steer a project D19, with the front wheels off the ground, they would turn with a long bar against the spindle.  Last week went to it and removed the front end.  Amazing, the steering seemed to work flawlessly when turning the stub shaft, like there was no problem.  After a while I grabbed the steering wheel to discover the universal joint closest to the bell housing was rusted tight!! Ouch
So, does anybody know a part number or even size of cross I'll need to repair the joint???  I haven't started digging yet, and hoped somebody could save some time!!
Thanks, Stu
I've got more time than money, and lately not alot of time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 10:13pm
I got one from DJS for my D17, fits D19 also. I choose to replace just the shaft cross bearing. $17.75. Comes with a grease zirk. Easy to install. Otherwise the entire universal joint is $130.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 8:26pm
Some of the after markets are too long and won't work.                 MACK
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 1:24pm
Weasler 200-0600
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 8:30pm
And they are a ***** to get off! That’s why I did just the cross bearing which is all that needed replacing anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 9:56pm
Thanks guys I ordered the cross from DJS, supposed to arrive Monday.  Weasler is about 15 miles South of me, that would have been great too!!  Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 11:19pm
Take your time when replacing it. After removing the old one, be careful as you place caps with bearings in them. They are greased in place and must be lined up correctly before you press the cross into them. It’s a little more difficult to do while the universal is still on the tractor but that’s how I did mine. I put a small socket facing outward in from the opposite side and used a C clamp to draw it together. Worked great.
