D-19 Power Steering
Nathan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Power Steering
    Posted: 15 Aug 2010 at 7:39am
 Just picked up a d-19 and dont have a service manual yet.  Where do you check/add oil to the power steering. also what oil should be used? thanks for the help  nathan
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 7:50am
If it's the same as the D-17 pull off the grille and you will see a fill plug on the top right side of the front support.
I use power steering fluid from NAPA.
Edited by Jeff Z. NY - 15 Aug 2010 at 7:53am
JCinPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 7:53am
I believe that should be in front of the radiator behind the grill.  Level should be 5/8" above the quadrent gear.  Use type a Automatic trans fluid.  JCinPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 8:12am
Type A was a real early type for GM cars.
Has been replaced by Dexron Fluids.
These systems on these old tractors work with almost any oil.
Transmission fluid, hydraulic oil, power steering fluid and even 20w non-detergent motor oil.
I believe the D-17 and D-19 have very close to the same steering units and back in the day Allis Chalmers said to just use a S.A.E. 20w oil in the power steering on the D-17.
Edited by Jeff Z. NY - 15 Aug 2010 at 8:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 8:24am
Thanks for adding that Jeff.  I quoted that out of the manual and after hitting the post button I realized that type A proly wasn't available anymore.  JCinPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 8:26am
Thanks for the information guys.  nathan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 8:29am
No Problem, If the D-19 manual says Type A they may have found they liked that oil better than the 20w they said to use in the D-17.
Then a Dexron would be the right choice today.
I remember many years ago A type for GM and F type for Ford.
Chrysler was a completely different beast with 7176, ATF+3 and ATF+4.
Edited by Jeff Z. NY - 15 Aug 2010 at 8:59am
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 9:48am
The 20w in the D17 is good because if the front seal in the pump leakes the oil  goes in to the engine.
Pullin With AC
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 10:07am
I would use the 20w engine oil. Just because of the new friction modifiers in the ATF could be hard on some parts in the pump.
This page was generated in 0.097 seconds.
