D19 power steering problem
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: D19 power steering problem
    Posted: 27 Nov 2018 at 7:18pm
I recently bought a D19 and the power steering comes and goes as you turn the wheel. I checked the fluid up front and it’s at the top of the gear. Could the pump be going out or need a system flush? Seems like it does it more turning to the right.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 9:50pm
I would reseal and adjust control valve. Also make sure steering shaft is not binding. Has to move back and forth.    MACK
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 10:59pm
May also check the pump pulley in case the key is stripped
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 2:01pm
Which parts do I need? Doesn’t list a seal kit, and I don’t have a service manual yet, unless it will be the same as a d17.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 9:24pm
All orings and # 3 seal.     MACK
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 6:26am
make sure belt is good if belt slips it will do that
