D19 power director question
bill(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill(IL) Quote  Post ReplyReply Direct Link To This Post Topic: D19 power director question
    Posted: 01 Feb 2010 at 5:46pm
Can someone tell me if a smaller outer shim can be used in place of a larger shim at position 2 center plate?   Thanks    Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 6:02pm
Long shims should always be used in the center......you can do what you want, but there is a reason for the long shims.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 6:28pm
The long shims support the center pressure plate backs and prevent dishing or warping, I have seen two short shims inserted in place of the center long shim with the tabs hung on each bolt and the rest sticking inwards, as I guess the repairer did not have access to a long one.  Anyway I would get the correct shims - and be darn sure the shim stack totals what the repair manual states.
