D19 PD Help Needed
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: D19 PD Help Needed
    Posted: 29 Jun 2019 at 11:00am
My power director seems to be loosing fluid around the handle shaft. I removed the handle/lever but find nothing but the casting and shaft. Looks like any seal must be inside?
I would appreciate any direction offered.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 1:45pm
Believe there should be a groove on each side of the handle shaft for an o-ring
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 2:10pm
Yes...supposed to be an O-ring in there....Rick
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 2:15pm
See attached pdf. The lower drawing and the lower group of part numbers apply to your question.
D19_power_director_fork_shaft.pdf
You can sign in as a guest user and access the parts book at AGCO Parts Books
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 9:53pm
I was told by an old timer that if you had small hands (or kids or grandkids ) you can remove the snap ring on the left and the handle off you could slid the shaft out the other side enough to expose the oring then replace it then slide back the other way and change the other oring then the little hands can help get the key in place as you slide the shaft back in place   Maybe the dr or somebody else can say yes or no about doing this
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 10:02pm
Remove the handle, remove snap ring on left side. Remove cover on right side. If there is a setscrew on shaft inside, remove it. Slide shaft just far enough to expose snapping and replace it. Move other direction and do the same.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 11:47pm
D-19 shouldn't have an internal setscrew, just half-moon keys. So, no need to remove right side cover. Place the hand lever fully into LOW range and remove the long handle from the shaft. Gently move the shaft side to side just enough to roll out old Orings and roll in new Orings from an AGCO dealership.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 8:28am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 8:46am
Thanks much for the replies. A very simple process once direction is received! Thanks too to the Dr. for bumping this back to the top. Not certain why my physical or site search came up empty.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 10:51am
I'm sure the AGCO o-rings aren't just plain general use o-rings so I'd get them from AGCO as the DR says
Wink
I am a Russian Bot
