D19 P/D hydraulic oil filling issue
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Topic: D19 P/D hydraulic oil filling issue
    Posted: 19 Sep 2023 at 5:58pm
Changing oils in my d19.Book says 5 1/2 gal for P/D hyd.Have only 4 gal in it and shows  over full. (1 1/2" over the after sitting mark ).Should take another gallon and a half. Oil  maybe doesn't seem to want to flow to the hyd compartment.What am I missing here?Both the pump sump and the P/D plugs were pulled when drained.
Edited by ac45dave - 19 Sep 2023 at 6:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 6:35pm
Pretty common issue. Leave the dipstick loose and let it sit overnite. Add some more in the AM if it will take any. Start engine and let it IDLE for a minute or two and that will help the oil work towards the front compartment. Re-check several times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 6:57pm
Will do. Thanks a million Dr.
Edited by ac45dave - 19 Sep 2023 at 6:57pm
This page was generated in 0.073 seconds.
