D-19 OEM Overhaul Kit |
Roger Chlian
Joined: 06 Mar 2014 Location: 10441 moe hall Points: 58 |
Topic: D-19 OEM Overhaul KitPosted: 13 Dec 2022 at 4:26pm |
For Sale: OEM sleeves-pistons for D-19. Tag on box says Deutz-Allis #74062376 4. For more information call RC at 320-760-6882.
Edited by Roger Chlian - 15 Dec 2022 at 10:36am |
Posted: 14 Dec 2022 at 9:01am |
So, are they gasoline?? diesel ?? or LPG ??
Roger Chlian
Posted: 14 Dec 2022 at 11:02am |
In original boxes and the Deutz Allis # is: 74062376 4
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Posted: 16 Dec 2022 at 8:06am |
You haven't answered Dr's question! Gas, Diesel, or LP?
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 16 Dec 2022 at 8:17am |
Pretty sure he has no idea.
Posted: 16 Dec 2022 at 10:23pm |
I can't verify what they are either with that part number. If they have a power crater bowl, they are gas or maybe LP gas. Flat tops are diesel even if they have one small valve relief cut in them.
Roger Chlian
Posted: 20 Dec 2022 at 11:23am |
Pistons do have a cut out. We are not able to get the picture posted due to size limitations? If I had your phone number I could send the picture via text message. my number 320-760-6882. Thank you. RC
Kenny L.
Posted: 21 Dec 2022 at 10:50am |
Roger send you a text
Kenny L.
Posted: 21 Dec 2022 at 11:08am |
Posted: 21 Dec 2022 at 12:18pm |
They are gasoline or LPG. Probably gas, as they didn't make many LP tractors.
NEVER green
Posted: 21 Dec 2022 at 1:07pm |
That dish looks pretty deep to be gas????
plummerscarin
Posted: 21 Dec 2022 at 3:38pm |
Look like the ones I pulled from my gas 262
Posted: 22 Dec 2022 at 7:04pm |
The only difference between gasoline and LPgas pistons is the piston pin hole location changing the compression ratio from 8.0 to 1 up to 9.35 to 1.
plummerscarin
Posted: 23 Dec 2022 at 4:48pm |
Service manual for D19 states center of pin bore to top of piston is 1.927 to 1.9345 for gas and 2.081 to 2.0885 for LP.
Roger Chlian
Posted: 23 Dec 2022 at 9:22pm |
Kit is for a gas. Thank you to all of you who helped identify this overhaul kit. I appreciated the help. Merry Christmas!
