D19 new problem! |
SD Allis ![]() Silver Level ![]() Joined: 14 Sep 2009 Location: SD Points: 55 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Mar 2019 at 4:28pm |
Why would or what causes the generator on the (new to me) D19, to get very HOT.
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Get it rebuilt before you burn it up.
soggybottomboy ![]() Silver Level Access ![]() Joined: 20 Feb 2018 Location: Iowa Points: 216 |
A low battery can cause a generator or an alternator to get very hot. Try putting a battery charger on the battery for a while.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21723 |
Question #1. Is the charging system working? Question #2. If it is working, what is the rate of charge?? should only be 2-3 amps unless you are running the lights. More than 2-3 amps of charge will create more heat. Question #3. How hot is it?? Just because you can't hold your hand on it doesn't automatically mean there is a problem, especially if the charging rate is correct. I suppose the rear bushing could be failing.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6045 |
Is it making any scary noises? What's your system voltage? Put a voltmeter on it... I don't know all the variations that would've shown up on the D19, but if there's a mechanical regulator on it, and the regulation armature contact is stuck, it might be running full field current, thus... full voltage... but you'd probably experience other very uncomfortable symptoms soon...
