D-19 lift question. ??? |
MACK
Topic: D-19 lift question. ???Posted: 23 Oct 2011 at 7:29pm |
Two way check valve needs reseated with new balls, copper washer and orings. MACK
mark-east-tn
Joined: 06 Oct 2009 Location: Rutledge Tn Points: 761 |
Posted: 23 Oct 2011 at 3:19pm |
I got the old 19 out today and hooked it up to my three bottom disc plow , after I raise it up and go back to nuetral position on lift valve it falls to the ground. Is there some kinda hold position valve in the valve body that holds pressure ? Thanks for any help
