D19 LIFT CYLINDER QUESTION |
CORY
Topic: D19 LIFT CYLINDER QUESTIONPosted: 23 Aug 2020 at 6:24pm |
Saw a D19 today and was looking at the lift cylinders for the snap coupler arms. What is odd is the cylinder rod that is on the left side as sitting on the seat is about half the bore diameter of the right side. The D19 that I have has the same diameter bore on both sides. Both cylinders looked to be original to the tractor but seemed odd that one would be half diameter of the other
Posted: 23 Aug 2020 at 6:37pm |
The model D-19 only came with the larger diameter rod, according to AGCOPARTS.com. I doubt very much that it came out of the factory with mismatched cylinders. There wasn't another A-C tractor at the time that D-19 was built that even had the smaller diameter rod, so it was changed out sometime in the last 60 years.
