D-19 Largest Mounted Attachment?
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Largest Mounted Attachment?
    Posted: 06 Jan 2025 at 8:03pm
I know this is a loaded question, but what's the biggest thing you've hung off the back of a D-19 (Snap Coupler or 3-point)?
Only reason I ask is that I have been offered a 3 point mounted 610 chisel (the one made by Jeoffroy for AC). The biggest thing I have is a D-19 and I don't anticipate ever needing anything larger. The chisel looks too big for it but I figured I would ask for the wisdom and experience of the forum.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:23pm
Oh… To be in a part of the world that doesn’t need spring trip on chisel plow shanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:59pm
Actually, we probably do. I got my CII from this guy and plenty of rocks busted the bottom of the grain header pan over the years. Go 10 miles west of us and no more big chunks of limestone.
I was at least able to lift all the rocks I found in my fields by myself this year, so that was nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 10:16pm
Is it category 3  ??? if so, it ain't for a D-19.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 10:46pm
wJohn, what tractor did the previous owner of this AC chisel pull it with?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 11:26pm
I see there's 8 shanks on it, but some have been removed & it's 3 pt. Do you have 3 pt on the D19.? Can it lift the chisel and drive with it, or does frontend come off grd? Do you have duals?
 The gauge wheels will help keep it from dropping to china & lifting frontend into air.  I'd try it with 6 shanks spaced evenly & gauge wheels set about 8" off ground setting on level hard surface then see if it will pull it that way. IF it has no problem handling it, set wheels higher or put the other 2 shanks on.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 5:53am
I've pulled a 7 shank with my 185. No trouble on power, but I have just barely enough traction with loaded tires.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 6:46am
D-19 gas, or diesel?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 7:29am
So probably if you had plenty of traction, you’d be low on power!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 7:50am
We ran a D19 for years loved it but no way it would have pulled that chisel plow in our red clay,Take off half the shanks to start with.I had a 5 tooth chisel I pulled with the 190XT I owned and the 190 had all it wanted.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 10:34am
Pull it with a well weighted tractor until something pops....going for  10 or 1000 acres???
Michagman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michagman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 6:16pm
I can't answer your question, but I have one of my own.  I assume it's a 3-point.  Has it been partially unbolted and folded down for some reason, or does the top link pin do double duty?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 7:24pm
The biggest tractor the guy had when he was farming was a 4020 diesel. I am now wondering if it was too much for the 4020 and that is why some shanks are missing.
Thanks to everyone for humoring me. I may buy it to cut it down into something smaller if the price is right.
This page was generated in 0.754 seconds.
