D19 Hydrolics |
Pa'sOldA/C
Topic: D19 HydrolicsPosted: 21 Oct 2010 at 3:26am |
My D19 gas burner has a hydrolic leak. The lift will not stay up and It is leaking fluid all over the shop. It will leak for days after you shut it off. Anybody have any ideas what it might take to fix it.
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Posted: 21 Oct 2010 at 5:52am |
Where is the leak coming from?
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Pa'sOldA/C
Posted: 21 Oct 2010 at 6:25am |
Not sure fluid is coming from the belly of the tractor. I figure there is a seal or internal hose that has the leak. I have a shop manual ordered.
DonDittmar
Posted: 21 Oct 2010 at 2:46pm |
3 spool setup or single?
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 21 Oct 2010 at 3:43pm |
More likley and external line going to the remote valve bank. The lift not staying up is probably the lift check valve in the valve bank, ya gotta split the valve in half. That is one part they did a poor job of describing its function and how to repair it. |
Pa'sOldA/C
Posted: 21 Oct 2010 at 7:35pm |
I beleave it is a 3 spool
Pa'sOldA/C
Posted: 29 Oct 2010 at 11:15pm |
Well got my manual in and its not a whole lot of help. I think I found a guy that can fix it. Thanks for all the help.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34440 |
Posted: 29 Oct 2010 at 11:41pm |
Check the pto shifter seal?
