D19 Distributor shaft and gear replacement parts |
David(Stockbridge)MI
Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Topic: D19 Distributor shaft and gear replacement partsPosted: 31 Jan 2011 at 6:16pm |
Have customer looking for gear and shaft for D19 Distributor that drives the tachometer cable, I know they are GM parts. Does anyone have the part numbers and where I can find them? THANKS David |
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 31 Jan 2011 at 7:30pm |
some people believe it is the same as some of the mid 60"s corvette drives, but the corvette one is about 0.060" smaller in diameter and then strips out the tractor distributor gear.. That is what I found out. if you find one that works out let us know.
Matt |
Butch(OH)
Posted: 31 Jan 2011 at 9:39pm |
Matt and I have had oppisate experiances with the 'Vette gears. We have the aftermarket gear sold for 62-70s Corvette in our D-19. Besides the obvious wear in the old one the 'vette part measured with in a couple thou of the one that was in it, was it original? who knows? All I know is we removed the distributor so we could check things out thoroughly, installed the gear and it ran as smooth as glass in the distributor machine. Ours it is still running the tach a year later,maybe the only one I dont know?? Worn shaft bushings will effect the mesh as will the brass bushing that the gear runs through. It is also available along with the trust button all as a kit or as individual pieces. Search "corvette tach drive gear" on Ebay. We bought from Virginia Vettes, darned nice people to deal with. Edited by Butch(OH) - 31 Jan 2011 at 9:45pm |
Butch(OH)
Posted: 31 Jan 2011 at 9:42pm |
goof up,sorry Edited by Butch(OH) - 31 Jan 2011 at 9:44pm |
Butch(OH)
Posted: 31 Jan 2011 at 9:43pm |
another goof up, sorry Edited by Butch(OH) - 31 Jan 2011 at 9:44pm |
Posted: 01 Feb 2011 at 7:45am |
THANKS Matt & Butch. Found some kit on Ebay and ordered a few set to take to shows and put on our web site. www.djstractorparts.intuitwebsites.com
Austin(WI)
Joined: 11 Sep 2009 Location: Wisconsin Points: 1462 |
Posted: 01 Feb 2011 at 8:39am |
Did that with our D-19 as well. It worked for a while then stopped. Here to find out that the gear on the distributor shaft is chewed up really bad. need to replace that shaft on there in order for it to work properly. Otherwise the vette one should work.
"Better By Design"
Posted: 01 Feb 2011 at 5:27pm |
Austin, where did you get a replacement shaft? If you don't mind me asking.
ALSO YOUR MAIL BOX IS FULLLLLLLLLLLLLLL
