D19 Diesel Oil pump Dr Allis?
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Topic: D19 Diesel Oil pump Dr Allis?
    Posted: 20 Jul 2017 at 10:52am
Have a local customer needing a D19 oil pump, and I don't have enough experience to understand why thee is a serial number break in the parts books.  I only see a couple of nuts different at the 121675 break.  I also cannot visually see any difference in the gas/diesel pumps, but I'm sure the diesel is running higher pressure?
JImD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 12:07pm
Gas/diesel oil pressures settings should be the same.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 3:05pm
So would the pump interchange?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 10:15pm
Yes, should be the same. Some had a relief valve on the pump along with the one on block. Some only used the one on block.    MACK
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 12:08am
Thank you!
This page was generated in 0.099 seconds.
