D19 3 point hitch leaks down
Mdguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdguy Quote  Post ReplyReply Direct Link To This Post Topic: D19 3 point hitch leaks down
    Posted: 12 Mar 2020 at 12:26pm
Does anyone have the agco parts numbers to fix the 3 point hitch from leaking down on my D19. I know I’ve seen/read them on here before but can’t seem to find them in the search.
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 12:47pm
Probably depends where your leak is. Here is a link to the parts book.
Farmin' with 1981 7010 PD, Great Grandpas 1947 Farmall H, JD 7000 planter, JD model B drill, NH 316 Baler, NH 1411 Discbine ,JD 100 8 Shank Chisel. Darke County OH
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 9:28pm
There is a two way check valve between top and bottom half that needs resealed and reseated.        MACK
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 12:19am
Mack can you explain further. what check valve are you talking about. thanks
If you choose not to decide you still have made a choice.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 7:36am
When you remove top half of valve stack, the check valve will be sticking out of top half. Unscrew with 7/8? Wrench, then use big screw driver to remove second part. There is a copper washer that is usually broken. Replace copper washer, drop ball into valve, with soft punch and small hammer pound on ball, loosen valve and retighten again. Repeat until it is seated. Replace orings and reassemble.          MACK
ditchman24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ditchman24 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2020 at 8:08am
Dose anyone have a picture or can point to it in the parts book? I have the same problem with my tractor.
