d-17IV
john n/il. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Topic: d-17IV
    Posted: 24 Feb 2010 at 11:49am
i have a d17iv that i want to restore .it burns or uses maybe 1 quart of oil when i use it say for six hours.my brother did a compession test on it and all four cylinders read 130psi.the tractor runs good otherwise .just want your opinion on what would you do.overhaul it all the way or just paint it and leave the engine alone for now.thanks john
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 12:18pm
  I would say it depends on what you plan on using the tractor for, if it the main tractor in a small farming operation then yes overhaul it. With 130psi on all 4 cylinders is good. I would suggest using an oil additive with the next oil change, I have had good luck with Lucas oil additive with some of my old tractors.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 12:33pm
I have the same problem with my HD6G dozer, except that I'm burning about 1 quart per hour.... But, I only use it about 10 hours a year (if that) so I'm OK with spending $30 in oil versus probably $1000 in parts (maybe more) and a lot of time fixing it.
How many hours are you running the IV every year?
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 12:53pm
Could be a broken oil-control ring on one or more pistons (though not too likely).
Or valve guides may be worn.  If oil consumption is not a concern, then this wouldn't be a major issue either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 1:13pm
thanks for the replies .I only use it at my brothers farm ,maybe 50 hours a year .I will try the oil additive this spring.Hopefully it will help.Im also missing the rod,upper position control linkage and agco doesnt stock no more.the three p. wont lower all the way down .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 1:55pm
John - I'd put a can of SeaFoam in the crankcase with your next oil change.  Helped my Gleaner EIII with the 226 gas engine to free up my rings and cut oil consumption after the combine had sat (and was lightly stuck) for 15 years before I bought it.   EIII too still burns a little oil but it runs too good otherwise to spend the $$$ to overhaul.  I run 15W40 in it but it only is used during summer & fall.
I found out 15W40 is to thick to run in my D17 Series IV that I did give a full overhaul to.  It's so tight it really pushes up the oil pressure so much it can blow the oil filter seal when it's cold out.  I have to get that checked out again this spring to make sure I don't have an oil-pump bypass issue.  For now I'm using 5W30 in the winter and 10W30 in the summer.
PM or e-mail my on your 3 point issue and tell me more about what linkage you are missing...I might be able to help you in both cases.
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 9:50am
skyhigh i sent you a pm thursday morn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 10:14am
Just replied with some hopefully good info.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
This page was generated in 0.035 seconds.
