d17,d19, 170 steering box output shaft seal |
juniorp53
Joined: 16 Mar 2012 Location: United States Points: 53 |
Topic: d17,d19, 170 steering box output shaft sealPosted: 08 Oct 2024 at 12:08pm |
seal that came out is 262fm124 C/R looks to be unobtainium the replacement agco #70229966 or 229966 if that makes you feel better. Seems the only seals available are about half the thickness(.750 vs .313) and lack what looks like a felt portion. what replacement seals are you guys using? are you double stacking them? filling it with 85-140 oil or 00 grease ?
i know i am overthinking this but id like to keep the oil in it for as long as possible
Posted: 08 Oct 2024 at 12:31pm |
Double stack two new seals and forget about it. You can't run anything heavy in that gearbox unless it's a 170 or D-series without power steering.
juniorp53
Posted: 08 Oct 2024 at 2:04pm |
tractor in question is a early 170 gas with loader
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 09 Oct 2024 at 8:53am |
You definitely CANNOT use grease in there!
Brian G. NY
Posted: 09 Oct 2024 at 11:18am |
This is the reservoir for your P-S fluid so, like the good doctor says, you can't put any type of grease in there.
Posted: 09 Oct 2024 at 11:32am |
On the mighty first generation One-Seventy's, the steering gearbox/bolster is just that...a gearbox. The power steering is getting its oil from the torque tube as it is a hydrostatic system with a triple section gear hydraulic pump hanging in the belt pulley hole..
