D17D Engine Rework Update
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: D17D Engine Rework Update
    Posted: 07 Jul 2010 at 7:35pm
Followup on my previous post. The D17D is blowing smoke again!!! New Piston/Sleeve in #4 hole and rebuilt head. Sounds as pretty as it did before the #4 intake vale seat fell out and destroyed the piston, intake valve, and sleeve. Time for it to start to earn it's keep; haaying season is here and it will be running a round baler for the next several weeks.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:54pm
What color smoke is it blowing?
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:04pm
It's blowing clear; except when it's throttled up, or pulling, then it blows some black out the stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 9:40pm
Did you have the pump off while you fixed #4? (pump timing) Don't happen to have a dirty air filter do you? Did you check the cam? My series 1 diesel had 2 lobes that were more than half worn off. It always smoked a little until it had just enough load to warm up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 8:22am
Did not remove the injector pump. Removed front end, oil pan, inj lines/injectors at the head, and removed the head. Removed rod bolts, pushed # 4 piston out, pulled sleeve, cleaned up the hole/O-ring grooves and reinstalled new sleeve and piston. After re-assembling the engine, I primed the fuel pump (removed the bleeder screw on top of the fuel filters) and left the injector nuts a little loose. Turned engine over and when saw fuel leaking from most of the inj nuts; tightened them up and it started within 5 turns of the engine. It runs real good and the rain cap stays level at idle; don't suspect worn cam lobes. I am looking for a new thermostat for it as the engine does not warm up (gage works when set the sensor end between exh manifold and intake water manifold.
Sorry, no dirty air filters; it has an Oil-Bath air cleaner, and has one of the earliest diesel engines in the Series I line.
