D-17
Cowman68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cowman68 Quote  Post ReplyReply Direct Link To This Post Topic: D-17
    Posted: 04 Mar 2013 at 8:01pm
I am new to pulling, I have a d-17, I want to get a few ideas on weight brackets for the front, middle and rear on a d-17
unstylish_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unstylish_ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2013 at 9:19pm
There is a guy on here from the upper peninsula of Mich. I think his name is Gary. He had pics on here a while back of a beautiful 17 he pulled. done really well.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2013 at 10:38am
if you text me 724-255-9904 i can get you some of mine i just finished for a pull in tallmadge ohio this past weekend  Shawn
190XT,D17and 7045
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2013 at 10:53am
 I can furnish more photos if needed, hope this helps ,  the weights I use are belarus that weigh 44# each.   Gary
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2013 at 11:12am
Thats a good looking tractor Gary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cowman68 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2013 at 3:28pm
Thanks for the pics of your d17 , its a good looking tractor. I don't have a weight bracket on the side of mine only on the front and rear. I can put about 350 lbs on the front and it's still too lite. I see your d17 doesn't have weights on the front just on the sides and rear, will the weights on the sides of your D17 hold the front end down good enough ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2013 at 4:00pm
 Well, as you can see the front is in the air, I like to be able to steer all the way down the track.....I feel that could have filled the side brackets and it have helped,  coulda went down a gear , too.   That hook was at the Tipp of the Mitt track in Onaway Mi,  I had all sorts of traction, that is one power sucking track !  But I won , sooo.........
This page was generated in 0.091 seconds.
