D-17
1970cougar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970cougar Quote  Post ReplyReply Direct Link To This Post Topic: D-17
    Posted: 06 Mar 2012 at 7:40pm
Will a WD engine block fit into a D-17?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 7:43pm
probably not recomended    main brg are different   d-17 would work better
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:09pm
Yes
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:13pm
i have d17 block for sale
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 6:16am
Technically Yes, but you are putting an engine rated at the belt of 34.63HP, in a tractor that depending on the series, was designed around an engine running 250 RPM faster, and rated at 52.70hp at the belt.  As you can see, it will work, but the tractor will not perform to your liking, but with some money you can change all of that.
Still in use:
D17countryboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17countryboy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 7:14pm
I would not recomend putting a WD engine in a D-17, I would recomend putting a diesel engine in if it had a gas job if you can find a diesel block for it.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 8:01pm
If you have a WD45 block and you want to switch your D17 internals over you can but you'll need the WD45 crank. If it's a later D17 you'll be losing the full flow oil system.
I suppose you have a D17 with a bad block and a WD45 or at least the block.
I would look for a D17 block, or an E Gleaner motor instead but you gotta do what you can afford to do.
Edited by Dave in il - 07 Mar 2012 at 8:13pm
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:43pm
The diesel engine is longer so it takes a different input shaft to the power director planetary from the clutch, longer hood sections and frame rails, longer front steering shaft, a different radiator, and different (longer) wide front end to convert from gas engine to diesel. Not that I'm discouraging the diesel D17 (I like mine), just better off with an original diesel to start with.        BTW, I see you joined today, welcome to the forum.
Edited by Brian Jasper co. Ia - 07 Mar 2012 at 10:46pm
