D-17
Heartland View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heartland Quote  Post ReplyReply Direct Link To This Post Topic: D-17
    Posted: 28 Jun 2022 at 6:52pm
Hello Fellers I’m looking for upper brake shoe pins for a D-17 series 4 any help would be appreciated
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 7:05pm
AGCO...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 7:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heartland Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 7:37pm
That’s the lower pins, they are to long and big around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 8:08pm
You should be able to get them from the same place you got your brake bands and disc lining from. In a pinch, I have actually used a long 3/8" grade 5 bolt with the head and most of the threads removed. It will work fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heartland Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 8:42pm
Is the D-17 the same as the 180 on brakes cause if so I can get uppers for the 180
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 8:43pm
Same parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heartland Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 8:48pm
Ok thanks man
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 4:57am
Agco part # 70237217 15.71
