D17 |
   MACK
      Quote   Reply
     Topic: D17Posted: 04 May 2021 at 9:13pm  |
   Don't know how big your bank account is.            MACK.
   Joined: 11 Sep 2009 Location: illinois Points: 88566  |
      Quote   Reply
     Posted: 04 May 2021 at 7:48pm |
   I have a B that was similar 15 years ago.. I bought a used sleeve for that hole... Bought all new rings , lapped the valves, reshimmed the rod and main bearings, new gaskets... all back together running great.
   jlogli
   Joined: 12 Oct 2011 Location: Stockport, IA Points: 862  |
      Quote   Reply
     Posted: 04 May 2021 at 7:23pm |
   Hello I’m at a crossroads where to go. I purchased a D 17 that was locked up took the head off and found number three cylinder liner was cracked in two spots. It was pushed into the water jacket area I’m guessing water got in the cylinder and froze during the winter time. The tractor is in pretty good shape and I hate to part it out but I don’t want to dump a lot of money into redoing the whole motor. Should I just pull the motor and replace one sleeve and put it back together or just put a whole new kit in it. Btw i’m looking for a whole set of valve retainer caps for it. Thanks jlogli.
     1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
