D17 with #190 corn picker photo's |
bozrae ![]() Bronze Level ![]() ![]() Joined: 02 Jul 2012 Location: Michigan Points: 165 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Nov 2017 at 4:46pm |
D15D, D17G, 170G, 175D, and two 5050FWA
Johnwilson_osf ![]() Orange Level ![]() Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 940 |
Awesome pictures.
How hard is it to take off and put on the picker? |
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Show me the ears. I'd like to see how clean they are.
tomstractorsandtoys ![]() Orange Level Access ![]() Joined: 11 Feb 2015 Location: wi Points: 515 |
Thanks for posting! I always liked mounted pickers other than the dirt. First picker I ever ran was a New Idea 319 mounted on a series II D15. Neighbor had a 190 picker like yours on a D17. I still have my John Deere 237 mounted picker in the shed all oiled up and put away. Tom
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3666 |
how much fun can somone have on the old iron
REEDE ![]() Silver Level ![]() Joined: 24 Apr 2010 Points: 286 |
Thanks for sharing . Like seeing the mounted corn pickers.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8377 |
Great shots! Of the 17 and mounted picker. Brings back some memories of Dad driving the 45 hooked to a new idea picker and me with the other 45 out in front just to keep it moving through the muddy spots. We were doing custom work on some of the wettest clay ground in PA.
Looks like your having a good time! Thanks for posting. Regards, Chris |
Stan R ![]() Orange Level Access ![]() Joined: 03 Dec 2009 Location: MA Points: 963 |
Neat picture.
This is the second year of my using the picker, last year is husked reasonably well, but nothing to brag about. This year was worse, the corn was planted late and there still seemed to be a lot of moisture in the stalk.
The picker is not as difficult to remove as it may appear if you leave the lift cylinder mount attached to the tractor. 6 bolts and undo 2 chains for the elevator. Remove 2 bolts up front for the lift mechanism, install jack stands, remove 2 more bolts at rear, detach 2 more chains then back out. The rear sub frame can now be removed by putting down the jack stands, removing 2 wedge locks and driving away. Of course putting the picker back on takes a little more patience to get everything lined up. Parking on a flat concrete slab will make the job much easier. All that being said, I never took it off last year and don't plan on it this year either.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 11725 |
HUH?! What'd you say? Haha....Nice pics though.
1terrygladys ![]() Silver Level ![]() ![]() Joined: 03 Oct 2013 Location: SW Iowa Points: 261 |
Loved the pictures. But next year, smile for the camera. ... Then you can be pickin and grinnin all at the same time!?!
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
southwindson ![]() Bronze Level ![]() Joined: 02 Nov 2017 Location: Kansas Points: 24 |
I think the pics are awesome. Makes me want one for my D17.
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3810 |
Hope you had a chance to use again this past fall!!! Looks awesome!
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
Didn't get the picker out this year. They are resting comfortably in the barn. Maybe next year.
TimCNY ![]() Orange Level ![]() Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Good Lord, so THAT'S what flat ground looks like!!! wow...
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2940 |
Nothing like some good mounted picker photos. I've still always wanted to drive one.
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4838 |
Bozrae , thanks for posting pics. I have never seen a screen box around the muffler. Is that homemade or a manufactured piece ?
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
